I tried to capture the exception case with the following code when the function of new_server is called with wrong scrpting server port ID or password.
try: s_o, g_o = new_server('localhost', outputport, password=outpass, error_mode=(RAISE))except: msgbox("Warning: the supplied scripting server port ID or password is not correct.") sys.exit()
However, it seems that the exception does happen even when I provide the correct port ID and password. Not sure how to get it to work. Thanks for help in advance.
Also, is it possible tp reset the port ID / password for the scripting server within the python code in the middle of the process? For example, after some tasks are completed, those settings will be re-set for the following tasks.
Thanks for the reply.
