Python - Boreholes and soil layers set using information from a csv file
Afternoon,
I have a csv file with:
- boreholes (1, 2, 3,..., b) characteristics ('x', head, 1st layer top level, 1st layer bottom level, 2nd layer bottom level, 3rd layer bottom level, ..., lth layer bottom level);
- material (1, 2, 3, ..., m) characteristics (to be assigned to each soil layer that each borehole).
Whilst I managed to get the Python script reading the csv files, trying to set boreholes/layers/materials in loops has been more complex (I would like the script to be run for as many boreholes/layer/materials as needed).  All examples I have seen, so far, are for basic ground models with horizontal layers defined by a single borehole.  Is there a way to set as many boreholes as needed, change the top and bottom layers levels, head, ‘x’ coordination in a loop?
From what I have seen g_i.borehole(x) creates Borehole_1, and if I repeat  g_i.borehole(x) Borehole_2 is created, and so on.  How can I access and change the characteristics of each borehole, using a Python script, for any number of boreholes >1?
How can layers characteristics be set for each borehole, and a material set for each of those layer, in a loop?
Apologies if this question has been asked before but, I couldn’t find it in the forum.
Cheers,
Joao
  • Dear Micha,
    I have uploaded the csv file to this response.
    1) The csv file providing the information of several boreholes which I wanted to use initially - layers levels are indicated as top level for the first layer, and then bottom level for the other deeper soil layers.  I was unable to set the levels inside the boreholes in a loop that could read the information from the csv.  My goal is to be able to access the borehole using a loop and changing the layers level using a loop as well.
    2) I guess that I am experiencing a similar problem by looping through polygons that meet a certain criteria, whilst trying to change the soil material of a specific polygon at a specific phase.  For instance dogin:
    for i in range(len(g_i.Polygons)):
        g_i.Polygon[i]  g_i.Polygons[i].Soil.Material = material   #material includes the soil parameters which are define elsewhere in the code
    The code does not work because g_i.Polygons[i] is returning a property and not directing to a specific polygon. See line 390 of the scritp in the zip file.
    Looping between phases and changing a specific property of a certain phase that meets a criteria has also no worked.
    In summary I guess that I am trying to access propeties when doing g_i.Borehole[i], g_i.Polygons[i] or g_i.Phases[i] than accessing the specific borehole, polygon or phase.
    3) I have attached a zip file that contains the Python script that reads the csv files created by an macro saved in the excel file - perhaps the file will help you to understand how vital it is for me to work with loops.
    Let me know if you need some further explanation. I am sure that there is a trivial way of doing this but I have not been able to find it.
    Best regards, Joao
    Boreholes_list.csvJV files.zip
  • Hi Joao,
    In order to set borehole layers from a csv we would need borehole elevation levels, in the script I see that you used thickness data? Is that correct?
    Q1 Borehole layers
    For the borehole data you could use this:
    • I used a function to read the csv file
    • I also created a small function to just retrieve the soil layer elevation from the csv file (from the excel file). If you change the boolean to False when calling the function, your attached csv file should work too
    • and I used one command to set the soillayer levels in just one line (this was added recently as a supported format in PLAXIS 2D CONNECT Edition V20 Update 3.
    import csv
    def read_data(csvfilepath):
        with open(csvfilepath, 'r') as csvfile:
            csvdata = csv.reader(csvfile)
            csvrows = [row for row in csvdata]
        return csvrows
    def getboreholelayerinput(cvsline, toplayerindex, isThicknessData=True):
        creates a list with borehole layer elevations
        :param cvsline: the line from a csv file, a list of values
        :param toplayerindex: index for the top layer elevation
        :param isThicknessData: boolean to specify if data is elevation or layer thickness
        :return: a list of elevation values top-down
        layerlevels = []
        # when layer levels are all defined as elevation, use:
        if isThicknessData is False:
            layerlevels = [float(i) for i in cvsline[toplayerindex:]]
        else:
            # when layer levels are defined as y_level_top, then thinkness values, use:
            layerlevels = [float(cvsline[toplayerindex])]  # create list of elevations. top down
            for ilvl in range(toplayerindex + 1, len(cvsline)):
                if 'na' in cvsline[ilvl] or cvsline[ilvl] == '':
                    break
                else:
                    layerlevels.append(layerlevels[-1] - float(cvsline[ilvl]))
        return layerlevels
    def createboreholes(csvfile):
        creates boreholes in a blank project
        :param csvfile: csv file with borehole data per line, has header line
        :return: a list of generated boreholes
        csvdata = read_data(csvfile)
        # column definition from csv file
        indexName = 1
        indexX = 3
        indexY = None  # 3D only
        indexHead = 2
        indexLayerLevels = 4 # column for yo_top_level
        # boreholes
        boreholes = []
        for line in csvdata[1:]:
            # create borehole
            if indexY:
                boreholes.append(g_i.borehole(float(line[indexX]), float(line[indexY])))
            else:
                boreholes.append(g_i.borehole(float(line[indexX])))
            # set name value
            boreholes[-1].Name = line[indexName]
            # set head value
            boreholes[-1].Head = float(line[indexHead])
            #set soil layer levels
            BHlayerlevels = getboreholelayerinput(line, indexLayerLevels, isThicknessData=False)
            # make sure we have enough soillayers: adding soillayers for the first borehole
            if len(boreholes) == 1:
                for layer in range(len(BHlayerlevels)-1):
                    g_i.soillayer(0) # jsut add zero thickness layers initially, correct later
                firstborehole = False
            #set all soil layer levels per borehole:
            g_i.setsoillayerlevel(boreholes[-1], *[(i, BHlayerlevels[i]) for i in range(len(BHlayerlevels))])
        return boreholes
    # start a new project and add boreholes
    s_i.new()
    createboreholes('Boreholes_list.csv')
    Q2 Looping over polygons
    It seems you are looping over all Polygon names in staged construction. In that case, the Polygon created in Structures mode has been intersected and now we have a cut object. If you use the name of the polygon, we could loop over all the polygon-entities that originate from that original name. And to set materials, you would also need to tell in which phase it needs to be done. Here is a small example
    polygonnames = ['PolygonName1', 'PolygonName2']
    phase = g_i.Phase_1
    material = g_i.MaterialB
    for pgname in polygonnames:
        if hasattr(g_i, pgname):
            pgobject = getattr(g_i, pgname)
            for cutobject in pgobject:
                # deactivate polygon:
                g_i.activate(cutobject, phase)
                # change material
                g_i.setmaterial(cutobject, phase, material)
    I hope these examples here help to get the script working.
    Looks to be an interesting way to automate these model generations.
    Kind regards,
    Micha
    Answer Verified By: Joao Ferreira Verde
  • Hi Micha,
    Thank you for the bits of coding. Those were super helpful to understand how the code should be instruction Plaxis. Now, things are running smoothly.
    All the best,
    Joao
  • Hi Micha,
    Is there anyway to determine the coordinates of the 'cutobjec't you have in your Q2 answer? I'm trying to deactivate cut portions of a BoreholePolygon (e.g. BoreholePolygon_1_1) based on coordinates.
  • Hello Sean,
    Typically we use the .BoundingBox of a polygon object to identify which is which.
    However, we are working on some further developments (still improving) on the geometry information in Staged construction I can share with you.
    Let's say you have Polygon_1_1 in Staged construction.
    Running the following command will give you the segments (lines) that define the polygon:
    echo Polygon_1_1.Geometry.Segments
    And if you want to know the points of each part, you can run this:
    echo Polygon_1_1.Geometry.Segments[0]
    This will give you x1, y1, x2, y2
    In Python naturally, you can do a for-loop to query all the values and remove any duplicates.
    I hope that this helps.
Reply
  • Hello Sean,
