Hi, i have a question regarding installing third party pythoon packages. Previously i could find the Python interpreter and the scripts folder, and from there install the packages using pip. I can't find this folder anymore. According to the manual, i should do the following:
When you want to install a third party package that isn‘t already available in the Python installation then you cando so by opening the command prompt from Expert > Python > Command prompt
If i do so, a command window opens (on the directory: Desktop). When entering a command line pip install "somepackage" it gives: pip is not recognized.
My question: How to install the third party package?
Dear Niels,
Check our latest article on this topic:communities.bentley.com/.../how-to-install-additional-python-modules-in-plaxis
Answer Verified By: Niels Zee
Thanks!
