Modelling CPT data in SVDESIGNER
I used a feature to import borehole data from gINT.  It assumed captions for fields and tables that are not actually in my gpj (BOREHOLE etc where I have POINT and PointID).  Also, I would have liked to select which PointIDs were imported, we don't always have a perfect complete data set in a database.
My actual question is, what can SVDESIGNER do with CPT Data.  Can I import and display it?  Does it form part of the modelling process? Do you have an example I can refer to?
  • Regarding the gINT import, our import dialog does support choosing which fields and tables to associate with what data, so they don't need to be in a specific name. I'm not sure if the user missed this or if something isn't working right there.
    SVDesigner can import and display CPTu data - it currently only handles this PWP aspect of CPTs at discrete sample points, not soil properties or anything like that. It doesn't get used in modeling other than that it can be included in the SVFlux analysis for calibration validation purposes. That is, the user can compare the analysis output PWP to the measured PWP from CPTs. There are no examples currently.
    Answer Verified By: Phil Wade
  • My POINT table doesn't have the caption set to BOREHOLE, but SVDESIGNER thinks it does.
    OK it can't import CPTu, but it can import dissipation tests.  Something for the future?  This was a major reason an end user didn't buy.
    Phil Wade
    Datgel
    Bentley Channel Partner and Developer Partner
    E: phil.wade@datgel.com | T: +61 2 8202 8600 & +65 6631 9780
    Get the most out of gINT with Datgel Tools.
Reply Children
