Modeling Plate element as cluster in plaxis 2D
Hi
(I edit post and put better images to explain problem better)
I model same problem in 2 way: once with plate element and once with cluster elastic element
in order to compare result i need force and moment in cluster case.so i model a plate element with reduced stiffness(factor of 1e-8) to capture forces(at output i multiply force magnitudes with coefficient of 1+e8)
i got some drawbacks.
 i got axial tension at joints and moment magnitude at corner is considerably decreased compared to modeling with plate element only.
Any one has any idea?
