Warning - very small embedded beam elements generated
Hello!
I am running a model with many embedded beams and plates on top (piled raft) and when meshing I am recieving this warning, "very small embedded beam elements generated". Is it something that effect the results?
How can I solve it? Tried meshing with medium and finer local mesh for the beams. I do not want to make vey fine mesh because then the model will take forever to run (have several long consolidation stages).
