How can I find the 3D Embedded Beam Slipping (sliding) between the pile and the soil?
How can I find the 3D Embedded Beam Slipping between the pile and the soil?
It would be the displacement of the pile minus displacement of the soil.
Is there an output function for that?
Thank you
  • Dear Kostis,
    Indeed, you are correct and in this case, you can use Python scripting to compute this relative movement of the embedded beam. For that, you could use the coordinates of all the nodes of the embedded beam element and find the equivalent coordinates from the soil side. In that case, the getsingleresult or the getresults commands can assist.
    Currently, there is no direct option to view this result in PLAXIS Output program.
  • Thanks again Stefane, it sounds a bit complicated, because the embedded-beam nodes (which I believe are created at the intersection with the solid soil elements), do not coincide with the solid-element nodes. It would be appreciated if this was picked up in a future version of Plaxis.
    I am not familiar with Python. What would be the best place for someone to start/ get exposed?
    Finally, similar question, what would be the best way to visualize what parts of the embedded beam have reached the interface side-shear capacity? It is kind of straight forward when the side-shear capacity is constant with depth, but gets tricky if it varies, and even more tricky if it is estimated by the program.
Reply
