Hi, I'm trying to automatically read out simulation results from Plaxis. For this I have oriented myself to the following how-to (LINK). However, the evaluation takes a very long time, because each step is queried individually. If the whole process is done manually (Curve manager -> New -> Node displacement as X-Axis, SumMstage as Y-Axis), then you are much faster. Why is the manual way so much faster than via a script? Is there any other way to get the desired output?
Dear Siegfried,
You are right that currently the performance when trying to retrieve the results of multipliers or in general the result type .Reached per step is quite poor. We are working on a solution for this that will improve the overall performance when retrieving results for both normal Output experience but also via scripting (i.e. via command line).
I have added your feedback to our report so that this is considered.
Answer Verified By: Siegfried Galkin
Dear Stefanos,
I have the same issue. I'd like to know if, after this time, exists a quickly way to save the Reached values step by step. The iterative way is not an option, it takes an hour to save a just 1000-elements array!
Hi Stefanos,
Is there an update on this? I have automized my workflow to run an optimization study, which needs to run many simulations. Alas, this .Reached method is taking almost the same time as an actual simulation run.
Thank you,
Ned
