How can I change the Groundwater level after a few Phases in Plaxis 3D?
I defined the groundwater level with the head in the borehole at the beginning of the model. How can I change it in the construction stages?
Probably I have to install a well, but how can I implement , that it lowers the groundwater level in Phase 5?
Thanks for your help!
Dear Jeremy,
Yes, exactly! The groundwater level is yet another surface defined in Flow conditions mode.
You can check a more complex example of defining water levels in PLAXIS 3D Tutorial 07: Rapid drawdown analysis - PLAXIS | SOILVISION Wiki - PLAXIS | SOILVISION - Bentley Communities
