Dear all,
I am trying to connect two plates using the custom connection. When I ran Plaxis 3d for a very simple model I encountered the following error "Picos solver: incorrect solution, slow convergence. [Error code: 204]." I would be grateful if someone can guide me on how I can figure out this issue.
Hi Plaxis Team, If I have created the custom connections but wish to remove them after that, is there a way to do so? I couldn't seem to find any delete option for the connection or deactivating it. Thanks in advance. Regards,Kelvin
By the way, there is no way to deactivate a custom connection as it applies as a global condition between the plates (and plate with beam). Once introduced you can configure the connection behaviour (rotation, translations) but it remains always active when both components are activated.
