How to get results for total stress on an interface in python PLAXIS api.
I'm at the stage where I think it is g_o.ResultTypes.TotalStress possibly or g_o.ResultTypes.Plate.TotalStress. Not sure what the command will be exactly.
  • Dear Iman,
    If you are looking results for plates then g_o.ResultTypes.Plate.TotalStress is the right one.
    In general, you can echo ResultTypes or dir(g_o.ResultTypes) and that will take you to:
    • g_o.ResultTypes.Soil
    • g_o.ResultTypes.Plate
    • g_o.ResultTypes.Geogrid
    • g_o.ResultTypes.EmbeddedBeamRow
    • g_o.ResultTypes.Beam
    Make sure to check the available results via the echo command, e.g. echo ResultTypes.Plate or in our Help>Command reference>Output objects
    Answer Verified By: Iman Warsame
Reply
  • Dear Iman,
