Move "everything" command
Hi
I want to move all the struture at the same time in a direction.is there any command to move them all once?
  • Hi ahmad,
    You can select the all nodes of the structure you need to move using "move" tool and specify the coordinates to what distance you need to move in command line.
    i don't know the command solely
  • Dear Ahmad Rahmani,
    You can move the whole structure using move command.
    For example I need to move all elements in Y direction for 2 m:
    I press Ctrl+A to choose all elements.
    Then I click right mouse button on the «red» elements and click on Selection label:
    The same thing you can do via Selection explorer.
    In that way I copy all elements' names.
    At the end I type move (or mv) in the command line and paste all info:
    Finally I should type XYZ value for direction. If it is only Y=2 m, so I type «0 2 0»:
    and press Enter:
    All elements are moved for 2 m in Y direction.
    I hope it will help you.
    Answer Verified By: Stefanos Papavasileiou
