What order should g_i.embeddedbeammat() for embedded beam row properties be?
I have the following line
g_i.embeddedbeammat(("MaterialName",deadman_material_name),("E",deadman_E), ("Width", deadman_width),("w",deadman_unit_weight),("PredefinedBeamType",2),("Lspacing",deadman_spacing),("SkinResistance",2),("Tmax"10000),("Fmax",200))
I am not getting the Width to show in the embedded beam row material properties so to work around this I removed the ("Width", deadman_width) from the above line and wrote material_i.Width = deadman_width underneath.
However, had an issue with material being invalid and not allowing calculation to happen. It says you need to edit/delete the embedded beam row material and if you open and then close it (without editing anything), it works absolutely fine. Which is a little strange, think it might be due to the order of the material properties, hence asking this question.
Parents Reply Children
