Hi all and Rushan Gizzatullin Stefanos Papavasileiou Dennis Waterman
Normal drain and vacuum drain both used to reduce the GWT but vacuum drain can reduce lower the provided head. I thought for normal drain we need to apply loading to reduce and for vacuum drain no need to apply external loading as it creates the vacuum which reduce the pore pressure and increase the effective stress (OBP + delta sigma), where delta sigma will be used as the external loadings.
But when i did the analysis using both, both provide same result without applying any external loadings as shown below.
Normal Drain:
Vacuum Drain:
Please tell the reason for this.
Hello all, I have one question about this, the head h=-2.0m you assigned to the drain elements is the total head corresponding to Y coordination in the model, isn't it? Thank you.
Hi Nam,
Here I have modeled the soil from y=0 to down and I needed to reduce the water level to 2m from the ground surface so I have provided h=-2.0m (y-coordinates).
Thanks.
Thank you, so it is the total head.
Yeah it is groundwater head, when you reduce it now elevation head is z= -2m and hydraulic head (Pw) = 0kPa, so total head = Z- (Pw/ gamma(w)) = -2 m.
