Hi all and Rushan Gizzatullin Dennis Waterman Stefanos Papavasileiou
Sorry if my questions are seemed to be very small things but i need to know the answers that's why i'm asking. My questions are
01. In the multiplier definition, what is the meaning of the amplitude here (as we defined unit load as dynamic load) ? does here amplitude value represents the load which is dropped on the pile to push in ?
02. When interface is provided, what is the purpose of providing interface below (in the sand area), even though there is no pile element?
03. Can't be used embedded beam element or plate for this pile driving work? if so then we can continue the analysis: for example if we are using solider pile deep excavation analysis, we will stimulate the solider pile driving effect and continue the analysis for each excavation phases?
04. In the pile driving phase, the pile is drived all in one go but actual situation is it has been driving step by step, in that case how we can stimulate the analysis as next half of the wave is negative ?
05. The displacement result from the pile driving seemed to the effect is only to base of the pile, but there is disturbances on the adjacent ground also due to driving and vibrations. Why analysis results not given that effect and if we need to see that result how to change the analysis?
Thanks.
Noted with thanks
Dear Mr. Dennis Waterman Dennis Waterman
After study the "interface around corner points" (as you mentioned previously), i have one question. 1) To what extend we need to extend the interface element when modelling rigid and soil interactions (as i found this statement in reference manual)?
For the plate soil interactions (i modelled using only 1 soil), what is the reason for sudden high change in the interface effective stress near the base of the plate? if it is not a real case how to eliminate this one?
An extension of 1 (soil) element is enough. More is not a problem, but not needed.
With respect to the high peak stresses, that is usually caused by the soil moving around the tip of the wall.
With kind regards,
Dennis Waterman
Noted with thanks, that increase in stress due to the point of rotation in the cantilever sheetpile and that's not come for anchored sheetpile wall.
Dear Mr. Dennis,
Here shall I apply dynamic load step by step (for each pile depth increment into the soil) to install pile to stimulate the pile installation effect ?
