Project fails at an early phase after modification
I am having issues with my PLAXIS 3D project of a bridge, the original file runs with no issues. However, I have modified the height of the bearing by increasing the bearing height (pink volume) and reducing the height of the pier, without adjusting any parameters or other components of the bridge it started to fail at phase 3 - footing. The error code is 111. Does anyone know what possible could cause this issue? Is it when I modified the bearing and shortened the pier caused increase of load? I have attached images of the bridge, location of pier and bearing and failure point. If anyone could guide me it would be really appreciated.
Parents Reply Children
