NaN found in stiffness matrix element. [Error code: 36]
Hello everyone ,
I got this "NaN found in stiffness matrix element. [Error code: 36]" in dynamic analysis "Earthquake"
I got this error just if I use Very stiff or soft rock material in HS-small model , and using compliment base boundary at the bedrock, in other words, if I used fixed or Visco at the base the error disappear.
could you give the reason and solution?
Best Regards
i
Parents Reply Children
