We are using Plaxis to assess the settlement of an embankment on firm to stiff clay soils in which the long term settlement is critical for an acceptable design. We are adopting the Hardening Soil Model with Small Strain Soil Model and are a bit confused on the value of power m to adopt for are soil due to varied understanding of the use of this parameter.
Understanding 1: this parameter is used to represent the increasing stiffness Eur with depth and cam be adjusted to mimic the actual variation in stiffness parameter with depth. Where there is no variation with depth a very small value of 0.001 can be adopted. True or false
Understanding 2: Adopt a value between 0.5 and 1 (or default value 0.5) to inform the variation in unload reload stiffness values based on the stress variation. This does not have anything to do with stiffness variation with depth but all to do with the stiffness values to be adopted at different stress levels. If so how do we model the variation in stiffness with depth.
Thank You Mr. Berk. I got the english article and other publications from the same source. They are very informative. I have now understood that it is the characteristic values.
1. What about the side resistance input value. For example, for a 10 metres thick homogeneous clay soil with 100 kPa as cu value and the alpha approach has been seemed suitable for the site. The ultimate side resistance is, 0.5*100*3.142*1*10=1570. The input value can be suggested as linear with, 1570/10 which is around 0 kN/m top and 157 kN/m bottom. Is this okay?
2. When you have pile load test results to calibrate the embedded beam value characteristics, how does one go about this?
Hi Jamal, you have some problems with the understanding of embedded pile and I would strongly recommend you to take a look at the reference manual again. In the example you give, you have to enter 157 kN/m all along the length, not linear. Plaxis will multiply this value with the length of embedded beam. If you have 10 m pile, 1570 kN.
Since this question is on a different topic, I think we should stop discussing these here. Have a nice day.
I see Mr. Berk. Thank you very much.
