"Warning: small embedded beam elements generated" messages in considerable long embedded beam piles
Hello PLAXIS team,
I currently using PLAXIS 3D V20 to work on a  complex model that I created using 3D 2017 in the past and every time I mesh the model I get a bunch of warning message saying that I have small embedded beam elements generated
This is weird since all affected embedded beams are long enough  ( ranged from ~ 15 m to 50 m in length) and I never had any meshing/calculation issues in the past using the previous versions.
I have already followed the suggestion given by Stefanos in this post, but of course without any luck, since my elements are not really considered to be small ones...
https://communities.bentley.com/products/geotech-analysis/f/plaxis-soilvision-forum/205690/warning---very-small-embedded-beam-elements-generated
Let me know if you require more information about the model itself.
Parents Reply Children
