Dear Support Team and PLAXIS users,
I am currently working on a research project devided into experimental, analytical and numerical axes. PLAXIS is one of the major digital tools of the ongoing research project. I have recently experimentally calibrated "HSS model" on PLAXIS using the cyclic triaxial test module. My objective, is to use this calibrated model analytically in 1D, is it possible to extract the mathematical formulations of the calibrated HSS model from PLAXIS and implemented in an analytical model? If possible, the extracted soil model would be in 2D?Thank you in advance.Kind regards,
Adnan Sahyouni.
Dear Adnan,
It's unfortunately not clear to me what it is that you would like to do. The mathematical formulation of the model are given in the Material Models Manual. Be aware that some of the equations of the model cannot be analytically solved, only numerically.
With kind regards,
Dennis Waterman
