Structural forces in volume: Plaxis 3D
I am dealing with modelling of cross passage between two TBM tunnels. I have created the TBM tunnels by using tunnel designer and since my geometry requires lots of trimming and joining of surfaces and volumes I have detached the TBM elements from the tunnel designer. I have used volume element for the TBM tunnel lining and assigned properties of concrete.
Now my problem is I cant extract forces from the TBM lining. I have cut a section as well and tried to see the the forces and it is not happening. Can anybody guide me how to do that.
Abhijith
