Greetings all,
I am currently running several thousands of dynamic nonlinear deformation analysis with approximately 15 k elements per model. As you may understand, with such numbers it is difficult to evaluate results manually.
I was able to prepare the models automatically following the command line outcomes but when it comes to post-processing, command lines do not show the commands for every step.
For example, to cut a cross-section and extract results manually, following is what I do:
1. Cut the cross-section using Tools>Cross section
2- Select the output type (say horizontal displacement at that phase)
3 - Click on the table icon by right clicking on the cross section
4 - Select all data
5 - Export to .txt
After doing this manually, I am able to utilize python because at this point it is independent of Plaxis.
Is there any way to do above 5 steps automatically by "Run Commands" option? I am a python user and I have tried to follow the python scripting guidelines but found it difficult to understand and put the pieces together to do what I want to do above.
Thank you
Oz
Thank you Stefanos for your swift reply.
'Plaxis Input' command line feature in getting model history generated as we prepare the model has been an excellent way to self learn command line scripting without looking for any major support while the same couldn't be found in Plaxis Output application.
Once Plaxis Output also features these session history as we operate, then we would be able to understand the way Plaxis taking and doing things and can be able automate our workings and focus on the analysis of results.
At the moment, I dig around using command function for syntaxes and then apply the same for single set results. And I'm not aware as to how Plaxis Output considers each click we do towards reaching the Cross-section curve Plots.
In this regard, I'm looking forward to have this feature in the next version.
Thank you once again for writing back swiftly.
I was wondering if there has been any development re. cross section outputting since this original post? As I cannot see a way to export cross section values for total normal stresses etc?
Dear Matthew,
Our upcoming release (coming soon) is going to include the extra results that are missing.
Just a little more patience and then you have it.
Dear Stefanos
Is there any update?
best
thank you
Hello Abed,
The latest version is out already: New releases: PLAXIS 2023.1
PLAXIS 2D 2023.1 Release notes
PLAXIS 3D 2023.1 Release notes
