Flow only analysis and fully coupled flow deformation calculation type
according to the manual the calculation type Flow only can be only used to perform a groundwater flow analysis in both un/saturated soils and no stresses shall be obtained from such an analysis, while on the other hand the calculation type Plastic is used to  perform a deformation analysis.
Does the Fully coupled flow deformation combine both types of calculation together? If the answer is yes, can we come to the conclusion that a Fully coupled flow deformation analysis gives the same seepage path/line obtained from a groundwater flow analysis ?
If the answer is no, is there anyway to obtain stress values out of a flow analysis or is ist possible to run a plastic analysis following a groundwater flow analysis?
Thank you in advance
Parents Reply Children
