PLAXIS 3D Meshing Fails
Generally we have problem with the meshing module in PLAXIS 3D.  The only time that we get a successful meshing of the program is where the project is made of horizontal/vertical lines/surfaces.  Otherwise, majority of inclined/curved/irregular surfaces/volumes ending up in a frustrating loop of failed mashing process due to surface/volume size.
Considering that some of the complex geometries cannot be simplified much and identification and fixing the issues are very time consuming, that would be great if I can have your advice on whether this is general problem within the PLAXIS 3D users and if yes, how to make this process quicker and more user-friendly.
  • Dear Ramtin,
    Sorry to hear that you experience issues when meshing your PLAXIS 3D model. We have made a huge effort to improve our mesher in our latest versions as we have seen some impressively complex 3D projects that, with the reasonable effort considered, produced good results.
    The suggestions by Martin are spot-on. I agree in general that a step-by-step process when building the model, intersecting, meshing is needed to ensure one has a workable model and easy to identify the reason for any issue encountered.
    All points mentioned in your last post should be clarified in the specific project you have. I would be happy to assist you with each one if you can please submit a service request: https://apps.bentley.com/srmanager/ProductSupport
Reply
  • Dear Ramtin,
