Safety Factors <1.0
Hi all,
Can anyone give some advice about unstable situations due to soil collapse. I mean, can anyone recommend a way to calculate safety factors (<1.0) if you got a collapse in plastic phase using only plaxis results (without a limit equilibrium model)?
Thanks in advance!
Francesc
Parents Reply
  • I'm not a member of the Plaxis staff. But I have a question about Jamal's suggestion. If you limit the MPhase to something like 0.5, then at the end of that phase you would  only have about 1/2 of the condition that you're trying to model. In the example in the pdf this would be 1/2 of the mobilization of shear stresses to account for the non-horizontal ground. Now if you follow this condition with a FOS phase which starts reducing the shear strength of the soil,and trying to compute equilibrium (for the partially complete prior phase), I'm not sure of how to interpret the meaning of the computed FOS.
    I my opinion (and  I could be wrong about this)  you can't calculate a valid FOS less than 1.0 using methods based on equilibrium, and Plaxis is great at calculating equilibrium. I'd recommend starting from equilibrium, say by removing the surcharge and then increase the surcharge to get failure.
    Martin
    Answer Verified By: Dennis Waterman
  • Dear francesc an Martin,
    Of course I am not part of the plaxis support system. I do agree with Martin here. What I gave is a rough estimation. Normally, in a situation like this, I use limit equilibrium, but to get a rough idea, I use the above approach. Most of the time in my line of work, I encounter some local failures, and hence to overcome that I use plaxis 2D with Plaxis LE. I hope this helps. Thanks Martin for your contribution.
