Hi there,
I have a question on how to determine the coefficient of secondary compression and the intital volumetric strain rate as part of the input parameters of the Sekiguchi-Ohta viscid model. The Material Models Manual suggests using a secondary compression index as an alternative to the above mentioned input parameters without any further information on how to specifiy it. Unfortunately I haven't found a lot in the literature about this subject. The second question is wether it is possible or not to derive the input parameters of the Sekugichi-Ohro viscid model out of the input data set of the soft soil creep model using the soil test tool by excuting back calculations?
Thank you all in advace.
Greetings
Dear Ahmed,
Apologies for the late reaction. It slipped my attention.
I have the following comments from our research team:
Answer Verified By: Ahmad Jazzar
