water level in Plaxis 3D
Hi all,
I'm starting to learn Plaxis 3D and i'm confusing how to use "create water level" option and I'm unable to find any videos relating that. Can anyone please explain?
Parents Reply
  • Dear Mr. Rushan,
    Thanks for the help again.
    If the excavation has embedded depth then we can use dry cluster and interpolate option for water level which will remove the failure on the excavated surface due to water pressure.
    but for the shaft excavation (which we don't have no any embedded depth, as shown below, without that base slab => got from net), how can we use cluster dry option? even normal defining water level also cause the failure due to positive stresses (water pressure > effective pressure)?
    Thanks.
