Undrained analysis A, B (and C)
Hi all,
I have some questions in these types.
01. Only consolidation analysis is possible after the undrained analysis in A and if it is B then manual said Su is needed to update. Please explain this statement.
02. Based on undrained A, it over estimates the Cu of the soil in MC but not in advanced model like HS method A (as it matches like real soil behaviour) , can you explain how ?
03. MC model is not correct model and lets say if I'm going to use MC model, which type is more suitable as every types has pros and cons for example A=> correct PWP calculation but over-estimates the Cu , B=> PWP calculation is not correct, C => total stress analysis only.
04. How PWP calculation in undrained B is not correct? and why C is not available in HS?
 One literature paper indicated like this for MC, A and B
Thanks.
