Hi all,
I have some questions in these types.
01. Only consolidation analysis is possible after the undrained analysis in A and if it is B then manual said Su is needed to update. Please explain this statement.
02. Based on undrained A, it over estimates the Cu of the soil in MC but not in advanced model like HS method A (as it matches like real soil behaviour) , can you explain how ?
03. MC model is not correct model and lets say if I'm going to use MC model, which type is more suitable as every types has pros and cons for example A=> correct PWP calculation but over-estimates the Cu , B=> PWP calculation is not correct, C => total stress analysis only.
04. How PWP calculation in undrained B is not correct? and why C is not available in HS?
One literature paper indicated like this for MC, A and B
Thanks.
Dear Mr. Dennis,
By referring to this paper.
PDF
Nitha.
Ok, so you found 1 paper for 1 specific type of clay somewhere in the world ....
And there are many reasons why not to trust this paper:
- The use the assumption in advance that the CU results are not good and the CD results are while that should have been investigated. So they're not investigating, they're looking to prove an assumption without explaining where that assumption comes from.
- There is no information on whether the CU test was properly consolidated and the CD test excess pore pressures.
- When doing a 15-21 days CD test on soft clay no doubt there are effects from for instance creep (and creep induces excess pore pressures, for instance)
- There may have been effects of suction around the failure area for the CD test, and suction may lead to higher strength for soft clays. But such effects cannot just be considered for general cohesion and friction angle values.
The biggest danger of using data from publications is that they're often for 1 specific soil under very specific conditions, and any conclusions cannot be used for other soils in other parts of the world under different conditions.
With kind regards,
Dennis Waterman
Noted, thanks.
Hi Dennis,
Can I just clarify on your response to Q2?
MC model is not an elastic model, is it as it has strength parameters and to me it's elasto-plastic, just like Hardening Soil but without the additional stress dependency, is it not?
If that's correct, then how undrained A produce realistic result for HS?
Thanks in advance.
Kelvin
Hi Kelvin,
Mohr-Coulomb is an elastic-perfectly plastic model, which means it's am elastic model with a failure criterion. As long as the soil doesn't fail, the soil behaviour is elastic, whereas in the Hardening Soil model the soil already behaves elasto-plastic when the stress state is not at failure.
So Mohr-Coulomb is nothing like the Hardening Soil model and Mohr-Coulomb is just not a realistic representation of soil behaviour. According to Mohr-Coulomb if you compress soil and then release it again the soil bounces back into it's original shape as if it was rubber without any permanent deformation. That is just not how soil behaves...
