I don't know if I did well my model using HS model.
In my case the model is related with a dam construction. I used 11 stages.
When I verified the modules adopted by Plaxis, I discovered Plaxis used Eur in place of E50. ¿Is that correct?
I thought the correct way to solve the problem is considering E50 when you put a new layer because you load for first time this layer. Please let me know if I analyze in a good way this problem.
The following pictures shows 1. Soil Properties, 2. The section where I reviewed modulus, 3. Graph including: Current Young Modulus (Extracted from Plaxis), Theoretical E50 modulus, Theoretical Eur modulus.
OK. Tried to delete the comments, I can't do that, so removed the content not to be confusing, you can delete if you can.
Thanks for your answer.
