Greetings, I conducted stability analysis of deep excavation at the final stage using Plaxis 2D analysis. The excavation depth is 15 m while the penetration depth is 12 m. When performing stability analysis, the plate element (diaphragm wall) has a large settlement at the y-direction, while the value is depending on the number step of the calculation. My question is, why the displacement of plate element at y-direction is larger than x-direction when performing stability analysis at divergence condition? Thank you.
