Hi all,
I registered the Plaxis webinar and the certificate use my forum name which is short form. Please tell how to provide my full name in the certificate (I changed to full name here from Nitha NN).
Thanks.
Dear NitharshanOn the Bentley Learning overview https://learn.bentley.com/transcript/ there is a link at the bottom called Problem with your transcript?
If will point you to http://apps.bentley.com/srmanager/Training
On the page, after logging in with your Bentley ID, make sure to select the category: Certificates related, see below.
Dear Mr. Micha,
Thanks for the reply and when clicked the link "Problem with your transcript?" it came like this.
Hello Nitharshan,
I will check with my colleagues in Bentley Institute and they will reach out.
Hi Nitharshan,Can you drop us an email on academic@bentley.com, with the email you registered, Plaxis webinar you attended and the Name you would want to have on your certificate? Kindly attach this certificate screenshot too. This will help us in assisting you further with your query.Thanks,
Best Regards,
Tanisha Naik Gaunekar
Dear Mr. Stefanos,
Thanks for the help.
