Extraction using wells
Greeting for everyone,
I am modeling an extraction well (using well element and GW boundary). I use Plaxis 2D and 3D with flow only (transient groundwater).
However, when I compare with the analytical method (Jacob and Thiems), the result shows different groundwater heads by increasing the time.
I have input the minimum head and discharge rate in m3/day for Plaxis 2D and 3D. As a matter of fact, the results from Plaxis show the same groundwater head levels by increasing time larger than 1 day while the analytical method showed that the groundwater head will be lowered by the time (> 1 day).  Is there anything else I can do to solve this problem? Thank you for your support.
