Plotting Graph using Plaxis LE 2D Groundwater module
Hi everyone, I am currently using Plaxis LE 2D, Groundwater module to run out a numerical simulation of transient seepage at levee. However, I am facing a small issue when generating the graph from the software. Does anyone here could kindly advise me on plotting graph as shown?
  • This graph can be plotted by first going to the top menu bar and click on Output then click on Graph Manager.
    The following window will appear:
    Then go to the Points tab and click on the Multiple Entry tab. Here you will have the option to select points on canvas or directly enter the coordinates.
    Choose which variable to plot for these points.
    Then once the calculation is finished, go to the results in Output. In the top menu bar go to Graphs and click on Graph Manager. Then go to the Points tab and select all points and click on graph:
    Then you can copy all data and plot it in another plotting software such as EXCEL.
Reply
