pile raft foundation, load sharing
in my 3x3 model of pile raft foundation, modeled as volume elements and with distributed load
I would like to know how I can know how the load is distributed, i.e. how much is for example the% of load that the slab takes, so Qraft / Qtot ,
also I would like to know about the graph for each pile of the normal effort as a function of depth, I get the forces from importing centerlines and then I select a pile
and I extract the table, but I see that at the same depth of -1m there are many values ​​and also at other depths there are two values ​​one soil and the other clus,
what does this mean?
  • Dear  Alfonso,
    The results in PLAXIS are displayed per node. Naturally in a pile raft foundation, there will be multiple piles with the elevation of -1, so in the table, you get to see all of them.
    In PLAXIS we do not separate the amount of load as to the PLAXIS analysis there is simply an out-of-balance to be solved and eventually, you get stresses and deformations. The first part is based on the geotechnical engineer to determine.
    I am certain that by doing some research you may find publications on this topic as it is quite a practical case worldwide.
