Hello Plaxis team,
I did a simple exercise to validate the conventional bearing capacity equation of a footing on cohesive soil. I considered a cohesive soil with Cu=50kPa, unit weight of 20kN/m3, and Mohr-Coulomb model. I also considered a footing size of 3mx3m.
The ultimate bearing capacity of a footing on ground surface was 2,895kN (322kPa), and a footing at 1m depth was 4,880kN (542kPa). The ultimate bearing capacity of a footing at 1m depth without a backfill was 4,100kN (455kPa).
As you see in the above results, the difference in bearing capacity due to 1m depth was 133 kPa (455 - 322), which suppose to be only 20kPa as a result of qNq term. Also the difference of bearing capacity due to footing backfilling was 87kPa (542 - 455), which suppose to be only 20kPa (unit weight times depth).
Do you have any explanation on the above results? I can send the Plaxis model files if it is required.
Dear Abraham,
Can you please submit a service request?
Then, one of our support engineers can help you in detail: https://apps.bentley.com/srmanager/ProductSupport
In the meantime, here are some useful links for you in case you want to check our verification examples:
