"Largest signal value up" doesn't work in Output
Dear,
I am using PLAXIS 2D 21.00.01.7. For one of my reports I need to change the Legend Settings/Colouring in the PLAXIS 2D Advanced Output program. However, when I uncheck the "Largest signal value up" box nothing is happening in the Output view. What can be the reason for that? How can I solve it?
Thank you in advance!
Kind regards,
Mitch Frissen
Parents Reply
  • Dear Mitch,
    I will also explain it here as more users could get to the same point of confusion as you did.
    The option in Output, by default, is considering that the largest absolute value is shown in Red colour.
    The detail is that this option will show the largest value in Red colour.
    In your case, the largest absolute value and the largest value are equal, so no change is applied to the plot.
    Compared to the case I showed where there is a difference, thus the change in the colouring scheme.
    I will pass this over to our developers to further improve the options and make it clear as to what you can expect with such an option.
