Hello,I have problem with bending two surfaces.As it can be seen in the screenshot the red surfaces can't be blended and the error message(The tool failed to create a surface between the polycurves.) appears at the bottom.The polycurves have been imported from a DXF file.I appreciate it if you can help me.Thank you.
Dear Pooya,
In order to be able to assist you with your project and identify the reason for the problem you experience, please submit a service request.
Then, one of our support engineers can help you in detail: https://apps.bentley.com/srmanager/ProductSupport
