I am trying to have multiple runs using Python scripts in PLAXIS 2D v.22. Analyses are performed smooth and well in the beginning. Nothing goes wrong, I take the desired outputs at the end of the analyses.
However, after a certain time / number of runs (~4 hours / ~100 runs ), an error window pops-up as shown below. In addition, I am also uploading the bug report generated by the program. At the first glance, it is seem to be related to the geometry of the model since Plaxis2DXInput.exe GeometryToJSONConverter_Virtual is indicated on the main thread of the reports.
I have tried to solve the problem on my own, as far as I understood it is related to Delphi, but I do not have sufficient knowledge in this area. I just want to perform analyses for a large number of runs. Below, I have listed some of my observations:
I can elaborate on the model if you want, but it is rather simple and I don't take any errors related to numerical calculations.
Thank you in advance.
3113.bugreport__.txt
Hello Mehmet,
Sorry to read that you experience a bug in PLAXIS. Typically when a bugreport appears PLAXIS enters a state that has crashed and from that point and on it might not be stable to continue. The option is there to try and continue, but I usually suggest users to restart the application.
In order to be able to assist you with your project and identify the reason for the problem you experience, please submit a service request.
Then, one of our support engineers can help you in detail: https://apps.bentley.com/srmanager/ProductSupport
Dear Stefanos, thank you for your interest and fast reply.
