Plaxis 3D Save failure?
Hi guys,
Getting a failure when trying to save *any* of my projects, even when opening and immediately trying to save over old, completed projects.
I've tried moving the project file and folder to new, "shorter" locations, removing the data.convd.rr5 file below, closing "open projects" in both Input and Output, resaving to a different locations etc, and a combination of all. The inability to save over old, completed, previously completely working projects is odd to me. Any help would be appreciated!
"Not all project files could be saved. Some possible causes and solutions are:
- Insufficient rights: save to a location where you have write access.
- Read-only location (e.g. DVD-ROM): save to a location that is physically writeable.
- Path too long: save to another location that has a shorter path length
- Files locked by another application (e.g. virus scanner or another Plaxis component): close all applications that may interfere with the files
Please address the problem and try again, or save the project under a different name. Note that the project may be corrupted if parts of it were written successfully, while other parts were not.
Details: File could not be saved: data.convd.rr5"
