Hi all,
I have to define the soil with ko = 0.8. Since the soil layer is not horizontal I need to use gravity loading to generate stress at the start. horizontal stress can be generated using poisson's ratio (v) in gravity loading (k = v / (1-v). Therefore for ko = 0.8 , v = 0.445, but when I assigned this one Plaxis said v is too high.
Please explain why is this and how to generate the stress for ko = 0.8 using gravity loading (as the soil layer is not horizontal.
Thanks.
The message occurs because a Poisson's ratio of close to 0.5 indicates that the soil is almost incompressible, which usually means that it's undrained. Since you're supposed to give an effective Poisson's ratio the software warns you that what you're entering more feels like an undrained Poisson's ratio.If you have a K0 of 0.8 there are two possibilities: 1) either the soil is normally consolidated and has a friction angle of 11 degrees2) the soil is overconsolidatedIn case 1 you could decide to ignore the message and it will give you the correct K0. But since you're clearly the Mohr-Coulomb model, which is an elastic model, the Poisson's ratio determines the K0 but also the compressibility and you kind of say now that your soil is almost incompressible. If that is not what you want you should move into using Hardening Soil where those are not coupled and you can just specifiy K0=K0nc=0.8 and a Poisson's ratio of 0.2.
In case 2 you shouldn't use Mohr-Coulomb to start with....since Mohr-Coulomb can't handle properly overconsolidated soil. For overconsolidated soil K0 and K0nc are not the same, while for Mohr-Coulomb they are and also linked to the Poisson's ratio. Hence, use the HS model, or HSsmall, or Soft Soil ....
With kind regards,
Dennis Waterman
Answer Verified By: Nitharshan
Dear Mr. Dennis,
Thanks for the reply and please clarify point no 1, how did you say the friction angle should be 11 degrees?
Just follow Jaky's rule : K0 = 1 - sin(phi)
Ah okay. Thanks
Please clarify this doubt also.
01. In advanced model like HS model, konc represents the normally consolidated at rest coefficient and ko is correlated as shown below (based on the plaxis reference manual).
How this equation is obtained?
02. If I enter konc value, after certain range, error message came, what is the reason and how konc is interconnected with the modulus?
03. How can ensure in ko procedure, whether the stresses are required only small equilibrium corrections or stresses are out of equilibrium?
