Hi all,
I have to define the soil with ko = 0.8. Since the soil layer is not horizontal I need to use gravity loading to generate stress at the start. horizontal stress can be generated using poisson's ratio (v) in gravity loading (k = v / (1-v). Therefore for ko = 0.8 , v = 0.445, but when I assigned this one Plaxis said v is too high.
Please explain why is this and how to generate the stress for ko = 0.8 using gravity loading (as the soil layer is not horizontal.
Thanks.
1) Please check the Material models manual, chapter 2, section "On the initial stresses".
2) The value of K0nc is linked to the stiffness E50ref through the shape of the compression cap. So not just any combination of Eoedref, E50ref and K0nc can be used.On the other hand, I see you want to enter a K0nc value of 0.7, which is really high, even for a very soft soil. And you also specify a friction angle of 30 degrees .... this is not a realistic combination.With kind regards,
Dennis Waterman
Thanks for the reply, there is one more question in the previous message, I typed here again
03. How can ensure in ko procedure, whether the stresses are required only small equilibrium corrections or stresses are out of equilibrium?
Dear Mr. Dennis,
Please reply to this question (One person put another (unwanted) message after my message).
Dear Nitharshan,
You can't ensure it .... but you as a engineer / PLAXIS user should recognize the situations where the K0-procedure is almost correct, or when K0 would really generate incorrect stresses. This depends on soil layering, water levels, existing (initial) structures etc.
With kind regards,
Noted with thanks
