I am able to export the Output plot using Python code, per the guidance provided in this article.
https://communities.bentley.com/products/geotech-analysis/w/plaxis-soilvision-wiki/45549/export-and-format-plots-from-plaxis-output
I tried out to output the plot of the Deformed mesh.
With the echo function, I obtained the following:
Plot named "Plot_1" ResultType: |u| PlotType: None (0)
For PlotType, I tried inputting "None (0)"/"None"/"0" into:
for phase in g_o.Phases: g_o.Plots[-1].Phase = phase g_o.Plots[-1].ResultType = g_o.ResultTypes.Soil.Utot g_o.Plots[-1].PlotType = 'None'
but the following error is shown below.
Invalid value: "None (0)". Allowed values are: nodearrows, contourlines, shadings, nodelabels or ordinal value.
Anyone knows how do I specify "None (0)" into PlotType as shown in the echo function?
Dear Arnkjell,
That is already possible by using the command: s_o.close()
Check our relevant article: How to open and close a PLAXIS project with Python
Thank you very much, that was exactly what I was looking for. It would be great if these commands could be documented a bit better in the scripting manual so it is easier for users to find the right commands.
