Hi guys
Is there anyway to output loads for all of my Plaxis run's staged construction stages, without having to extract the necessary output from each stage individually?? E.g. axial loads within node-to-node anchors or moments/shear within plates etc. for ALL stages in one table output
Dear James,
Results in PLAXIS are given per object type (soil, structure type: plate, beams, etc.) per step (and phase) per node or stress point depending on the result you query.
We can create tabular results that correspond to each phase as this is the typical workflow when using PLAXIS Output.
With the given functionality, you need to turn to Python automation to collect the data and present them in any way you prefer, e.g. same axial loads for specific or all node-to-node anchors for all phases.
https://communities.bentley.com/products/geotech-analysis/w/plaxis-soilvision-wiki/45453/output-scripting-example-get-anchor-force
https://communities.bentley.com/products/geotech-analysis/w/plaxis-soilvision-wiki/45452/output-scripting-example-get-maximum-bending-moment
communities.bentley.com/.../combined-plate-results-in-one-chart-using-python
