Compliant base for dynamic analysis
Good morning,
I am wondering if the compliant base at the horizontal base of the model is capable or not to dissipate also downward waves with both horizontal and vertical direction (model with horizontal line displacement for the horizontal component of the ground motion applied at the base and fixed vertical displacement at the base).
Has anyone tried to run a dynamic analysis applying, instead of the fixed vertical displacement for the base, a vertical accelerogram with zero amplitudes?
Thank you in advance,
Andrea Balia
Parents Reply Children
