Hello
Will you share the script in the webinar ? communities.bentley.com/.../coffee-corner-geotechnical-analysis---more-efficient-plaxis-usage-with-python-api---am-and-pm-sessions-available
Can we download and use it?
Thank you
Dear Nam,
From SciTE I see that you are using PLAXIS 2D CONNECT Edition V21 Update 1. Is that correct?
Note that the script was tested for PLAXIS 2D CONNECT Edition V22.00 with Python 3.8.x. In our latest version, the command embeddedbeam is used from now on. For the older version, the command was called: embeddedbeamrow.
https://communities.bentley.com/products/geotech-analysis/w/plaxis-soilvision-wiki/45991/plaxis-2d-command-compatibility-notes
You can manually replace this command in your script however I cannot guarantee everything will work as this script was created to work in a newer version.
Thank you, Stefanos so much!
It works perfectly now.
