Plaxis 3D converting Files from V21 to V22
Dear Sirs,
Whist opening a file that was computed using V21 with V22, it appears that all of the results and mesh were lost during converting of files.  Historically, Plaxis versions were forward compliant, however, this does not seems to be the case at this instance or I am missing something here.
P.S.  The results loss could be very annoying and time-consuming if a recalculation is required.
Many thanks
Nadeem
