Hi PLAXIS team,I have tried to convert to .dxf format with the command shown in the picture below. After that, I want to import that .dxf data to PLAXIS 3D LE but the object can't be found. So I can't export any data. Do you have any suggestions about this?Thank you
Dear Ganjar,
I was checking your question today. Note that if you want us to quickly check your question, please submit a service request. Then, one of our support engineers can help you in detail: https://apps.bentley.com/srmanager/ProductSupport
About the issue you report, it is difficult to say as we do not have the model or the data you use.
Have you tried exporting it in Soil/Structures mode?
Have you tried exporting as a STEP file?
We can assist you further if you need help, via a service request, of course!
