Dear
Does the Plaxis 3D have the “Parallel GPU solver and computation” to analyze the models, which could be time-consuming, to reduce and save the time of analyzing the models?
If yes, where is it located? How could I access that to solve and analyze the models?
I would be thankful if you may please guide me in this process
Thanks for your response
Sincerely
Amir Farshadfar
Dear Amir,
PLAXIS does not utilize GPU yet. We only utilize the physical cores of the CPU to run parallel calculations and processes.
Here are some useful topics for you:
Answer Verified By: Amir Farshadfar
Many thanks for your information. I have a question.
My computer is the Octa Core (8) core computer.
I mean could I choose the maximum 1 cores per phase to be used and at the same time select the Picos (multicore iterative) option to use the Picos ability?
In principle, the power of PICOS comes from the fact that there is an iterative procedure and it benefits from solving the system of equations in parallel on multi-core processors. That is also explained in the article I shared before.
If you use PICOS with a single-core then you lose the multi-core solving of the equations but you keep the iterative procedure, which many times is better than the Classic solver.
Regarding the fastest way to run an analysis, this really depends on what you are analysing. Every project is different (2D or 3D), with lots of details, structural elements, etc.. It is difficult to answer whether one or the other will have a better performance unless we test your project.
In general, when using more cores, the calculation kernel will need to divide the calculation over the different processors (cores/CPUs). However, this comes with some costs: the calculation needs to be split, and then the results should be merged. After some testing, we found out that a small number of elements divided over too many cores actually becomes slower to calculate. For that reason, we have a threshold value for the number of dofs (degree of freedom, dof) per core, which is about 10,000 dofs. So, if this number becomes too low, we just use fewer cores not to slow down the calculation.
For larger models, you will see an increase in the number of cores used.
In your case, you will need to test what is the optimum performance for that specific project, is it 2 cores per phase, so you compute 4 phases together or 4 cores per phase so you compute 2 phases at a time.
Can we simulate the a 1 km 1.7 km 70 m large land sliding by the Plaxis 3D?
Can we simulate the 1 km * 1.7 km * 70 m large land sliding by the Plaxis 3D?
