Is it possible using python to output plots of η?
For example can do IncrementalDeviatoricStrain using: g_o.Plots[0].ResultType = g_o.ResultTypes.Soil.IncrementalDeviatoricStrain
Thanks - I will try to upgrade as it doesn't seem consistent.
Have upgraded to V21.01. Can get it to work sometimes (i.e. using command first time on opening file, or using the jupyter console like shown in the gif), but then stops working.
Hello Glen,
I am not sure what is happening there, but if you want us to investigate more I would kindly ask you to submit a service request as via the forum it is difficult.
Then, one of our support engineers can help you in detail: https://apps.bentley.com/srmanager/ProductSupport
Dear Stefanos,
When I apply this command to a model containing only norsand, it works well. However, when I use it on a model with multiple non-norsand materials, it doesn't work anymore. Is there any way to extract norsand variables from a model with multiple material models?
Thank you.
Best regards,
Gian
Dear Gian,
Do you mean the getsingleresult command? This is supposed to show the result on a specific location by coordinate, for example. I am not sure I understand how you get results from other materials that are not at that location.
Can you please elaborate what command you run and maybe paste a screenshot that shows what you mean?
